Sets how forwarding of packets to local network IP multicast addresses (224.0.0.x) is handled.
fast-path |
Specifies fast-path forwarding. Fast-path forwarding dictates that packets traversing the switch do not require processing by the CPU. Fast path packets are forwarded entirely by ASICs and are sent at wire speed rate. This consumes additional system ACL per-port or per-VLAN, depending on configure igmp snooping filters [per-port | per-vlan] selections. |
slow-path | Specifies slow-path forwarding (default). Packets are processed by the CPU. |
Slow-path forwarding is the default configuration.
The following example sets up fast-path forwarding for local network IP multicast addresses:
configure forwarding ipmc local-network-range fast-path
This command was first available in ExtremeXOS 15.3.4.
